Been having weak charging problems so decided to swap in a mosfet rr thinking that would fix my problems.
I'm not sure if I checked the stator correctly but meter said it was putting out 14-20 v ac. The stator wires seem ok but do get hot.
At idle I'm loosing voltage from the battery. If I rev to 2000k ish rpm then I get 12.9-13.1 volts at the battery. But.. If I rev it more then It goes back down to 12ish volts.
Any ideas as to why I'm loosing voltage with higher rpm?
The warning indications are as follows:
Green, light charging fine, The window is about 13.2 to 14.8 volts.
Green and red alternating is over voltage (over 15.2 for a standard battery monitor and 15.0 volts for a Shorai battery monitor, not good)
Amber, (bike running) hook up a voltmeter on your bike and see what's happening with it running.
Red or red flashing means your bike is probably not running and you have your lights on, or if your bike is running there is trouble in paradise and you need to take action not to get stranded.
