Hi Guys
Here is my situation. I just installed a set of HID Ballasts off from Ebay (truly plug and Play) at first when installed everything was perfect for 2-3 startups. Now neither wont start when switch is turned on or bikes motor is running. The only way they both fire up is by holding pressed the pass on button, if high beam button is in the on position the both lights will flicker or fire when pass on switch is trickled, if the high beam switch is in the off position , only high beam will light up when emulating this procedure. Now my parking lights are not working , so as my left front mirror signal. Dash is Ok (lights up) lights are ok , haven't checked fuses but if they light up when executing this procedure there is power , so no use. Can anyone help me sort this out? I've read people reversing polarity on the low beam, I don't know this seams like a house of ghosts in this bike.Here is to say I'm running a gear indicator as well connected to the rear plug in the trunk of the bike, disconnected it and nothing changed, Please help me out.
God Bless
Pepe1098
God Bless
Pepe1098
