1 - 11 of 11 Posts
Can someone post a pciture of their left side stock rearset? Or even better, if you have a schematic/fiche, that would be good. Just putting the stock ones back on. Thanks.
Discussion Starter #5
It is, but it only shows where to bolt the peg assembly to the frame. I'm looking for a schematic of where the shift linkage attaches to the peg/rearset.
Does this help?
FlyerLen, any idea what the torque specs are for the rearsets?
Part Thread (mm) Nm ±10% Tolerance Notes
Bolt securing footrest to frame 8x1.25 24,0 LOCK 2
Bolt securing heel plate to footrest bracket 5x0.8 5,0 LOCK 2
Gearchange lever tie-rod locknut 6x1 10,0
Gearchange lever clamp retaining bolt 6x1 10,0 LOCK 1
Gearchange rod to lever retaining nut 6x1 10,0
Brake/gearchange lever pivot bolt 8x1.25 23,0 LOCK 2
Locknut for rear brake pedal adjuster screw 6x1 2,5
Rear brake linkage to brake lever pivot bolt 6x1 5,0
LOCK 1 Low-strength threadlocker. Loctite 222
LOCK 2 Medium-strength threadlocker, compatible with oil. Loctite 243
1 - 11 of 11 Posts
