1 - 20 of 39 Posts
sup guys!
sooo im not sure if i seized the motor or not. i was out riding and hit a straight, pinned the throttle and when i got to about 140 the bike lost power. i could still turn the throttle and it would go but it was making quite a racket (think straight piped harley decelerating). i decided to find a safe spot to turn off but when i pulled the clutch in the bike completely died. couldnt start it either. when i tried bump starting it and the wheel just locked up.
got it home and put in a fresh battery off the tender and tried to start it, well the terminals decided to start smoking. so i quickly stopped doing that haha
not sure what the deal is with it and dont want to dig too deep because its going back to the dealer in a couple days. anyone want to take some stabs at what might have happened?
The first part sort of happened to me and it turned out to be the kickstand switch. It just suddenly died but I was on deceleration. After I stopped, the bike wouldn't start no matter what until I jiggled the wire coming out of the kickstand switch. Since then, the only time it's acted up is when I put it into first when taking off, it'll think the kickstand is down when it's in fact, up.
Don't know what to tell you about the terminals smoking... Don't have any advice on that one.
Discussion Starter #4
i did check to make sure the belts were still there and they looked fine, but they definitely couldve skipped a tooth. which would make sense, i originally thought that the belts had broke or something. how do you know if they skipped? the timing marks?
oh, all of the fluids and what not were normal at the time as well. bought it 8 hrs earlier from a dealer and only put about 100 miles on it.
Discussion Starter #5
ive had stuffs like that happen on the 848 but this wasnt like that unfortunately! it sounded like a straight piped harley decelerating. or something of the sort
If it jumped timing it might still crank freely but probably not start. We need a better description of exactly what it's doing when you try to start it... or better yet, a video.
I really doubt it actually seized. If that happened at 140mph you probably wouldn't be here.:laughing:
Discussion Starter #8
well when i try to start it it clicks and then the terminals on the battery start to smoke. nothing moves at all. ill try and grab a video this afternoon
yeah i had slowed down to about 20 when i tried to bump it and locked the rear wheel. wouldve been one hell of a ride had it happened at 140!!:laughing:
Ooooooh, I missed that part about the rear wheel locking up. Ouch. You may be screwed.:( But if you just bought it then the dealer should take care of you since it's clearly not something you did.:ahhh:
Discussion Starter #10 (Edited)
im hoping they will! theyre picking it up on wednesday and we shall see.
im just really curious as to what happened. ive never had a catastrophic failure on a ducati in the 30k miles that ive owned em. (guess i was just lucky)
sup guys!
Sorry mate but I think it's stuffed.
That does not sound good. Reminds me of when I rebuilt my old R6. I didn't measure out all the conrod bearings when I reassembled. Needless to say it was a tad tight. It ran fine for about 30 miles but then it started losing power and sounded rough running then as it approached idle speed it quit immediately. Wouldn't turn over from that point on. A tear apart proved my fears. Blued connecting rod and scored crank journal.
Banned
Yep, I'd have to say bad rod bearing as well.
I was just discussing this in the 848 section about someone wanting to buy a high-mileage 08 848. The rod bearings on the 1098/848's were a huge problem until the Evo2 motor.
Sorry to hear about your issues. Been there, done that, I still have the destroyed shells somewhere in my garage. ;)
Discussion Starter #17
either spun rod bearing or completely destroyed rod bearing sounds about right. im sure if i took a look through the oil it would look like half the motor was floating around in there.
hopefully ill find out soon, thanks for the guesses!
Tye, when you say Evo2 motor are you referring to the 848 Evo's engine from 2011 and up?
Yep, the 2011+ machines were updated considerably.
What's different besides the piston crowns, intake ports and throttle bodies? Maybe valve overlap? I was under the impression that there wasn't much change.
1 - 20 of 39 Posts
