Hello guys
I recently bought a 1098R, everything is OK but it keeps running when the side stand is down and shifting to first gear, as I know, engine should go off. I'm not sure if engine can run at all when side stand is down, even in neutral. Since this logic is different even between 996S (can't run with side stand down, even in neutral) and 996R (runs with ss down and neutral) and maybe also vs. other Ducati types, need some advice in this topic. How should 1098R work ?
The bike has installed the Race ECU and complete 70mm termis, I also swapped the ECU to the street type, but there is no difference. As I know there is no side stand dongle installed, maybe the picture tell more, have no idea what's the white plug with the black plugin. I already searched the forum for this particular issue regarding 1098R, but could not find any hints. Please help.
