:violin: my most recent problem with my 1098s. I was on the freeway and the bike backfired a couple of times and died. The dashboard flashed and locked into service mode. I turned the key off and on a few times and it unlocked itself out of service mode so i started the bike and drove off with no problems. Thirty minutes later I jumped back on the freeway and it backfired once and died. once again it locked in service mode. When you turn the key on the dash cycles through all the lights then locks into service mode dissabling the starter switch. The battery has plenty of juice. Could this possibly be related to the VR recall?
Anything's possible with these stupid things.:mad:
Has the VR upgrade been done on your bike? An aluminum heat shroud isnplaced behind the VR and ECU to insulate from the heat. If this has been done, then start checking fuel control relays.
Good luck
