Oil cooler nipple on crankcase
14x1.5
32.0
LOCK 8
Cooler oil hose connector on crankcase nipple
16x1.5
25*
Lubricate with engine oil
Oil hose union on oil cooler
16x1.5
18*
Bolt securing oil cooler bracket to cylinder head
6x1
10.0
Bolt securing oil cooler pack to bracket
6x1
10.0
Thread (mm)
Nm ±10% Tolerance
mine leaked from top line where it attaches to oil cooler and a 1/8th turn tightened it back up after 8k miles and never leaked again but I traded it in at 9800 miles. these things vibrate so much it doesn't surprise me more doesn't loosen up. bottom line I tightened too but it was not leaking.
-Carbon
If a line is leaking, is a Re torque sufficient or should the line be replaced?
Tightening everything up should do the trick.
Follow the specs enclosed above..
