Got this recall notice from my dealer. Will be taking it in as it gets warmer. Any one else get this?
Panigale Chain Guide and Anti-rotation Insert
Models: M.Y. 2013 and 2014 1199 Panigale and M.Y. 2014 899 Panigale (all model versions, all country versions)
Technical Service Bulletin TSB-15-001
SITUATION:
In response to reports concerning clutch slave piston noise heard by the Customer when using the control, DMH Quality and Engineering Department research determined that it is possible for water to seep into the clutch pushrod. To address this concern, the below technical change is being provided to improve sealing of the clutch pushrod
This upgrade includes the use of two new components:
1) A new chain guide with built-in O-ring;
2) A new anti-rotation insert with built-in seal.
Please be informed that the two new parts entered into Ducati production in two different steps:
1) On the first batch of production motorcycles you will need to install both the chain guide with built-in O-ring + the anti-rotation insert with built-in seal.
2) For the second batch of production motorcycles you will ONLY need to install the anti-rotation insert with built-in seal (since the chain guide with built-in O-ring is already installed).
