OK, check this one out... I'm going to write a short story here... I went for a ride on Sunday and maybe after 15 kilometers or so I experienced a problem. I was going around a corner slowly (around 5mph) and when I tried to give it a little throttle coming out of the turn... nothing. The engine was still running but no response from the throttle control. I looked at the instrument cluster and I had the amber engine EOBD indication illuminated as well as a red engine warning flag. I pulled to the side of the road and shut the bike down. I restarted but the EOBD indication was still present and there was still no response from the throttle. I tried a couple more times and finally the EOBD indication cleared, the bike started and I was able to move off. However, the engine felt and sounded like it was running on one cylinder or something and I could smell fuel, exhaust, I don't know. I drove along around 10mph and the bike shut off again about 100 meters down the road with the same symptoms (amber EOBD light on, red engine flag on, no throttle action, no power). Again I was able to get going and this cycle repeated itself two more times. There was one instance when the engine RPM surged slightly a couple of times although I didn't change the throttle position... the bike did it by itself. The last time the bike stopped I was ready to call for help and was in the process of doing so when I decide to give it one more try... voila, I was able to get the bike to fire back up and this time the bike was perfect, full power, beautiful. I drove it home without any problems.
I let it sit for a couple of hours after returning home and then tried it again. I drove about three kilometers and then the problem returned, same symptoms. Each time this failure occurred and I received the amber EOBD indication I was still able to start the bike but as long as the EOBD inidication was present the throttle was unresponsive. I wiggled wires and keyed off and on each time until I could clear the EOBD indication, then I could start the bike and the throttle would respond. Sometimes I would have to wiggle things and cycle the key many times in an effort to make the EOBD indication disappear. I don't know why I did it but one time I opened and closed the gas cap and the EOBD cleared. Now this really sounds stupid... while trying to get the bike back home again, every time the bike would sputter out and the EOBD light would illuminate, if I opened and closed the gas cap the EOBD light would clear when I would key the bike back on. I could wiggle everything on the bike, key off and back on 10 different times, and still have the EOBD light... but if I opened and closed the gas cap I could key the bike on and the EOBD light would go out.
Since I don't know what the problem is I have to consider all possibilities. Was something done when it was serviced that might have caused this problem? Last week I had the shop flip my front sprocket. My chain was getting into the swingarm because the front sprocket was installed in reverse. From what I've read I'm not the first owner to experience this. The shop also brought the front end up 1/2". If you measure from the top of the triple clamp to the top of the fork tube you should have 10". The previous owner had lowered the front 1/2". Before putting the fairings back on when I brought it home from the shop I cleaned up the bottom of the bike real good. Did I soak an electrical connector? I don't know. Is this just a new problem that's not related to anything (shop work or my cleaning)? Again, I don't know. I am however somewhat inclined to believe that the problem is electrical as opposed to mechanical. Mechanical failures don't often fix themselves. Electrical problems on the other hand are sometimes intermittent in nature and as I mentioned above the bike went from running like a dog in one instance to running perfectly normal a short time later. I went through 90% of the electrical connections in the past two days. I found two three-pin connectors on the left-hand side of the bike that showed some signs of corrosion. One of these connectors goes to the RPM/speed sensor feeding into the engine. The other connector I'm not sure where it goes to yet... I ran out of daylight. According to Ducati literature there are instances when the EOBD light will illuminate and initiate an engine lock... but I don't know what that means. Does it mean it won't allow the engine to start or does it mean that the engine may start but you will not be able to give it any throttle? I don't know. Also, with regards to the RPM/speed sensor... is this sensor used in the rev limiting circuitry to cut ignition pulses at high RPM? Could water or corrosion in this connector have caused this problem? The connectors that exhibited signs of corrosion I cleaned well and put back together. I've cleaned and checked 90% of the connectors and electrical connections on the bike including a check of all fuses and battery and ground connections. I noticed too that the wire to my rear spark plug had a couple of indentations in it where it passes between the frame and the underside of the gas tank... probably caused by the intense heat generated in this area. Was the insulation compromised and intermittently shorting to ground? I repositioned the wire out of the way.
I tried to recall as much as possible regarding the symptoms. Does anyone have any thoughts?
I put the bike back together last night and it sounded OK when I started it. Today I'm going to have to take it for a spin and see what it does.
