1 - 3 of 3 Posts
I am at my wits end.
Starter engages briefly but then disengages immediately.
Starter changed, solenoid checked and ignition relays swapped with no change. Bike will happily start if you disconnect solenoid low voltage line and provide 12 volts to this from another battery. Have pulled apart switch and no obvious issues. Ignition relay clicks when starter switch actuated - either relay same result. Exact cable upgrade fitted no change. Problem has slowly gotten worse - sprang clutch replaced also as was worn.
Help please - such a nice bike but this issue is killing me.
Discussion Starter · #2 ·
I have since replaced the switch assembly - no change. Will change start solenoid and see how that goes - yet to test clutch and side stand switches but will do so and report.
Problem seems to have worsened to current condition over the last 12 months.
ECU is DP so will also check std ECU and report
Have now tested clutch and sidestand switches - they are working correctly. Will go back and confirm no issue with battery as I have not actually tried starting with jumper leads attached - can’t say that I am optimistic though.
Failing that, I will look at earth to battery and after that I am at a loss….
More than 110 have looked at this thread but no one has made a single comment - help!
1 - 3 of 3 Posts
