I'm needing some advice trouble shooting the reason my 1998 748 won't start.
What I've done so far. History. After replacing a failure and short in the connector from the stator to the Voltage Regulator rectifier while on the road the bike ran just fine. I tested the VR with a Mulitmeter. Battery was charging at 14volts at 5k rpms. I rode it for a few days but noticed that it was slow to crank and sounded like it had low power. I tested the battery (it's a year old) and it's holding 12.6 volts. A few days later with a fully charged battery I got nothing. Turning the key to on it appears to have power, fuel pump whirls to life, injectors prime, and running lights are strong but nothing. Only the Solenoid clicks.
I've replaced the Solenoid, the Voltage regulator, the two relays under the seat and still nothing, checked the wiring and still nothing....
Does anyone have any other ideas that can help?
Thanks.
Thanks.
