Hello peeps, I have searched all over with Google and this forum and can't definitively find an answer as to which direction LOOSENS the Flywheel nut (Holding the stator/rotor assembly). I am trying to get the nut off with a 1/2 impact but it's not budging and I don't want to spin it the wrong way and ruin the end of the shaft. It looks to be counter clockwise tightening nut so one would think I should be trying to turn it CLOCKWISE to LOOSEN it... Just want to be sure! Also, do I need a special tool to get the flywheel off? Thanks!
*edit I have had the Starter sprag replaced once already on this bike and after several thousand more miles it leaves me stranded from time to time when I ride because it won't start. Lately it hasn't started at all and the starter seems to be binding. I have already removed the LEFT side cover and found that the BOLT holding the starter gear is broken and it looks like I'll have to use an EZ OUT to get the rest of the bolt out of the case.... GULP.. but maybe this is why the starter wouldn't turn over after a few cranks. Hopefully the starter sprag clutch assembly is still OK. I'm thinking about putting a lighter flywheel in while I have it torn down.... I found info on here saying 900-950 grams is the best fit for the 1198....Suggestions?
