1 - 3 of 3 Posts
Hi All, I’m need to the Ducati family and picked up my 2009 Ducati 848 about 4 weeks ago.
After picking her up, I took her to a local shop, to have tires replaced, all the brakes/radiator and also clutch fluids flushed/replaced.
Once I got her back, I feel that the clutch seems too stiff, and Not like the way I tested her out before. Everything works fine, but stiffness tires my fingers (I used 2 fingers, pointing and middle fingers on my clutch) after a long ride. Is there something which can be done to solve this or make the clutch a little smoother? Thanks in advance for you help.
If your bike had a larger diameter aftermarket clutch slave cylinder when you brought it in, and now has a smaller Ducati slave cylinder coming out of your local shop — that would explain the increase in lever pull needed.
Discussion Starter #3
Thanks for your feedback, Shazam. I will look into a getting a slave cylinder.
1 - 3 of 3 Posts
