1 - 10 of 10 Posts
Hey guys,
I changed the timing belts on my 2011 848 Evo. It starts fine but when I put it in gear it revs but doesn’t move much. I m guessing I messed up on lining up the slots on the cams. I have attached some photos for your input as to if I messed it up. Thanks for any help you can provide.
Automotive lighting Automotive tire Motor vehicle Rim Automotive design
Automotive lighting Motorcycle Motor vehicle Steering part Automotive tire
Automotive tire Motor vehicle Automotive design Alloy wheel Rim
Cam timing, however you did it, has to be in time I would think. That is one section of the bike is a single spinning output shaft.
Then there is a gear from crank to gear to trans. So with engine running, goes nowhere, it's not cam timing per say.
Dead engine; back wheel off the ground; hand shift to top gear, buy moving the back wheel forward and reverse by hand shifting the trans to top gear.
Move the back wheel and begin to turn the engine in top gear. Can you do it? Now, pull the clutch lever in and hold it down with a rubber band, zip-tie, and the break the back tire loose off of the clutch assembly, by slamming the wheel up and down. Eventually the wheel should spin free or drag a little, but could spin a 360° with lever pulled.
Discussion Starter · #8 ·
The photos were taken at horizontal tdc. Using the mark on the case and pulley.
stefan_1: The photos you posted are of a 848 or 1098. The 848 Evo has different cam timing. At horizontal tdc the slots on the cams are supposed to face toward the cam cover on both cylinders.
· Super Moderator
This is correct - 848 & 1098 are the same as photos @stefan_1 posted, 848 EVO & 1198 the T 's point to 12 o'clock on the vertical cylinder and 3 o'clock on the horizontal.
That said everything looks fine to me, have you double checked any wiring connectors that were disconnected? And check your fuel lines, make sure they aren't being pinched somewhere whenh the tank is lowered.
Did you do any other work when the bike was apart?
Discussion Starter · #10 ·
I purchased the bike late last year. It had been sitting for a better part of 3 years.
Work I have done:
  • Front and rear brake flush
  • Brake pads changed
  • Spark plugs
  • Clutch fluid flush
  • Timing belts
  • New gas
  • New oil
  • I also upgraded the regulator to a mosfet one
BOTT I tried what you suggested and the following happened.
I was able to cycle through the gears by hand by moving the back wheel back and forth. I put it in top gear and spun the rear wheel with the clutch lever pulled in and the rear wheel spins but does have some resistance. I tried that in all the other gears and found that there is a lot more resistance in the lower gears especially in 1st and 2nd with the clutch lever pulled in.
I m guessing some of the clutch plates might be stuck together after sitting for so long? Also when I picked up the bike the clutch lever was not held by a zip tie or anything to relieve pressure on the clutch pack.
I have check all the cables and what not and everything is plugged in.
1 - 10 of 10 Posts
