Setting up the suspension better for my featherweight butt on the 2013 848 corse special edition.
Let’s call it 145lb nekid weight 155 dressed. Rarely am I in full leathers, usually a summer jacket and jeans.
With the factory rear Ohlins and 1091-24/80 spring backed out I’m at 11mm static and add 8mm (19 total) for rider rear so a long way from where I need to be (front is 25 static and 13 rider 38 total with preload backed off completely however at that is completely mismatched to the rear and I have them 3 turns in presently as closer to 22/12 totalling 34mm. Not right but it’s more predictable presently.
The front seems easy and whilst the factory spring is close I believe a lighter spring will allow better fine tuning. Order a 9.0 spring for the Showa forks and seals and new oil and I should be well inside the ballparks to get what I need at that end.
No way in hell is the 80 rear spring suited to me despite every “table” having it for The 140-160lb range. Not a chance and I’m not going to rush out and machine my nuts down to lessen preload as it’s not even close. I’ve ordered a custom spring 57/160/70nm 7.1kg/mm or 400lb/inch depending on what you like to call it. Let’s call it basically a 1091-18/70 but in red. Bit of a guess as nothing adds up but know I need significantly lighter. It’s been somewhat possible to tame the bucking nature of the rear with dampening but I’m that far off it’s not really safe to get real keen on any corners, the rear is light, both ends tend to skip and it’s a right dog 😆
And yes I know suspension is done to death. Soz to jump in the ring straight up with this but has anyone switched out the rear Ohlins to a 75 or 70nm spring and logged some sag figures for their new and old factory spring against butt weight and preload ring position?
More curiously has anyone gone lighter than a 70?
