Parts are removed from a 2013 1199R and a 2014 1199R I parted out.
Please PM me what you're interested in.
Prices are plus shipping and assuming you pay using friend/family method on paypal.
1. 1199 SWINGARM BOLTS-
2. 1199R Marchesini Rims $1709 shipped! Rear rim is near perfect, front rim has a couple small scratches from removal- i forgot to remove the calipers before pulling the axel out and the rim tapped the brake calipers.
3. Handlebars with clip ons $100
6. Clutch master cylinder & slave cylinder with braided line $70 - no lever or reservoir or reservoir bracket included.
7. Kill switch $40 ( i have 2)
8. Ohlins TTX-GP Rear shock 2 track days on it $1100
12. 1199R main harness(2 of them) $100 each
13. ABS Control module (2 of them) $105 each
15. Fan and fan shroud $40
16. OEM Horn (i have 3 of them) $5 each
16. OEM Fuel pump $75
17. rear brake master cylinder $40
18. Kickstand- Includes mount and sensor with pivot bolt $30
19. Left and Right side electronic holders $30 for both
20. Gold Pro-Ti Sprocket flange nuts- x6 of them $80
21. Ducabike Sprocket Carrier Black & Red (Type III) $130
22. 41 Tooth rear sprocket (Supersprox) with front sprocket $130
23. Brand New Carbon Fiber gloss upper chain guard $95
24. Brand New Carbon Fiber gloss shock cover $125
25. Brand New Carbon Fiber gloss brake line on swingarm cover $85
27. Swingarm- 1199R adjustable- includes hub, axle, brake caliper mount, rear brake caliper, rear 41 TOOTH sprocket $700
30. Ducati Performance CF Heel guards-$115
32. Ducati Performance CF Shock cover- $120
33. Ducati Performance CF Swingarm cover with lower chain guard- $300
36. oem Grips $20
37. OEM Exhaust $148
38. OEM Windscreen $29
40. Front V plastic fairing, coolant reservoir with fan and fan shroud $95
41. OEM Rearsets with linkage and DQS $209
42. Brand new carbon fiber race rear subframe in Matte. Brand new in box. Shiftech brand. $1696. If I can't get the $1696, I'll keep it.
43. Subframe gas tank mount- both pieces with all nuts/bolts. $60
44. 2x Forward gas tank mount bracket $20
48. 2x OEM battery $25 each
49. Set of O2 sensors- $20
