Has anyone else had a problem with the 821clock resetting when turning the engine off? I keep setting the clock but every time I turn the bike off the clock is reset to 00:00.
Any suggestions?
Thx.
Any suggestions?
Thx.
Does the clock say time or am pm.....time is run time....am/pm is the clock
The only mechanism that would erase the clock is a dead battery...or perhaps a loose connection to the dash...or a weak ground...or a loose ground at the battery....does the trip mileage go to zero? It would if it's loosing power...if it isn't...I'm clueless...if it is...start looking at the battery...then the chassis ground...then the clip to the dash....clip to ECU... something isn't right
