it sure does to me. confirmed - look at the picture.
Thanks! An offline buddy sent me the same picture this morning. Yep, it's confirmed. Thanks again!it sure does to me. confirmed - look at the picture.
More like; they didn't put back in correctly.
If you remove the cam pulley, you probably be able to push it back in place.
I do not think you need to remove the pulley nor will it help. Pull the cover off, remove belt, pull the cam out reposition the seal put it all back together. I've had my cams out so many times on valve adjustments I can do it with my eyes closeThank you, Dutch. This sounds easy enough. I have not yet worked on this part of my bike, so for special tools, these are the only two I need to remove the pulley, right?
I'm just not sure he can push it into position with the cam torqued down?It can be done in several ways.
But seeing at your first picture, you already popped the cylinder cover and drained the oil?
Didn't notice that before, saves you some trouble and time.
So what Tchase said is also a option, but depends on what you prefer.
Just be careful with the shims. Don't loose/drop them.
The tools you showed will do the trick, but you will need to replace the slotted nut when you do it the way I mentioned.
Another option would be; leave everything in place and push it back in place by hand or some other tool that could do the trick.
Be careful not to puncture the seal.
^ that's how i did it on my 1198 as well. if it's on the horizontal only then you might save time by not having to redo the belt tensioning. of course the vertical head will require the tank to be removed etc so removing the pulley might be the easier on the vertical. that said if it was me i would probably pull everything to make sure there is nothing else going on.
Thanks T--I decided the only way to salvage my last track day (scheduled for tomorrow), would be to take it in and let one of my local dealers help fix it. They took me in as a last minute appointment and all is well now. They replaced the seal and the castle nut. I guess I'll get to experience this myself the next time. I'm going to go ahead and get the tools so I'll be ready the next time!See the bottom seal, I do not think just pushing it back would be the correct way. I make sure it lines up putting the entire cam assembly (gear attached) in.
