Alright. Where do I start....
Took my 1198 in for the 7500 mile maintenance, the dealer breaks I. Down to start the valve check and said they heard quite a bit of air while turning the engine over. After a pressure drop test, I get a call saying they found 34% leak down in the horizontal cylinder and about 28% in the vertical cylinder. I gave them the okay to pull the heads off and check the exhaust valves (which is what they were suspecting). Now that the heads are off, they're saying I need to replace ALL of my valves, and that I have some minor scoring on the cylinder walls. Which they suspect to by caused by the piston rings. Now I'm lost. I've already raccked up a healthy bill just by them pulling the heads, but if they have to pull pistons, it would get ridiculous.
From my knoledge on cars, you can tell when piston rings go bad because of oil consumption, blue smoke and that sort of stuff, but I don't have that issue on the 1198. Sounds to me like I'm getting the run around? Some opinions would be greatly appreciated
