I currently working on a 2004 749R to a it will not turn over. the battery is fully charged, I have tried the other keys including the RED key. I have tested the solenoid and bench test it will 12 volts and it works fine. When you press the start button to diagnostic light come on and head light goes out. when you check fault codes it show 19.1 fault- Starter solenoid short to power supply, I check the solenoid and it wiring and found the diode is not working and if you hold the start button on the Grey wire that runs to the solenoid becomes warm and will get hot if you hold the start button on.
Any ideas guys?
