How often do you guys do chain maintenance?
M monster821 · Registered Joined Feb 15, 2015 · 18 Posts Discussion Starter · #1 · Apr 9, 2015 Only show this user How often do you guys do chain maintenance?
tjs5012 · Registered Joined Dec 8, 2013 · 52 Posts #2 · Apr 9, 2015 Only show this user Every 600 miles. Clean, tension, lube.
T thiz11 · Registered Joined Apr 13, 2015 · 12 Posts #3 · Sep 9, 2015 Only show this user What is the metric size of the axle nut?
L Leroy · Registered Joined Sep 6, 2015 · 39 Posts #4 · Sep 10, 2015 Only show this user After every ride while the chain is warm I lube it. I use Motel. Other lubes out there that are equally as goog. My rides are usually around 300km Leroy
C ChasT · Registered Joined Feb 22, 2015 · 81 Posts #5 · Sep 11, 2015 Only show this user thiz11 said: What is the metric size of the axle nut? Click to expand... 36mm, needs to be a multi face socket.
