Hi All,
This is probably a dumb maintenance query but worth an ask before paying money to be looked at funny / failing my upcoming MOT.
My 2011 848 Evo is stock apart from Termi slipons. The rear brake doesn't seem to light up the brake light. It used to (I regularly check) and the running lights are on as usual with the front brakes firing up the bright light when on. So its probably not a fuse...
Is there an obvious check I should be doing. i.e. electrical connections or pressure switch on the rear brake lever?
Cheers in advance.
Cheers in advance.
