I had to take the clutch case off my 916 and put a heli coil in the oil sending unit since it was stripped . I must have done something because when I started the bike up I had no RPM, and the Gen light and low fuel stay on until I put it in first gear. Then they go out. How strange. Also there is a oil light on the Tach that is red and when the engine is started it goes out, which I think is good, but the problem is that if I disconnect the wire going to the oil sending unit the light does not come back on. Any help is appreciated . BTY this has the 955 motor.
