1 - 8 of 8 Posts
Re: 1995 Ducati 916. w/7000 miles
Hello Guys,
I have a brand new battery in. When I turn the key and set the switch to run I here the fuel pump very clearly kick on. When I hit the start button to start the bike it'll turn a few times and I will here a clunk sound and then hear a what sounds to be wining noise. If I do it again and play with the start button as if timing it to the rotation of the motor I can get it to start after a few tries. Once its running its fine. Even after running it for 15 minutes and the motor is hot I have to go though the same process again after shutting it down. Please let me know what to check, thanks for your time.
Welcome to the forum!
It does sound like you aren't getting enough amperage into the starter motor OR the starter is bad. So it's trying to turn over, but doesn't quite have enough umph to get past the compression stroke.
A video of this issue would help a lot. :)
1 - 8 of 8 Posts
