Good day to ya,
Getting some issues solved with leaking plastic QD's, led me to pull the bung with the pump and other components.
Most of the internal fuel lines for the overflow and the filter were turning to mush. I know the sad quality of gas today is the culprit.
Anyway, does anyone have a recommendation for a quality replacement fuel line for these bikes(especially the submerged ones?
Automotive tire Wood Automotive wheel system Gas Rim
Napa Part Number: NBH H209
Gates 27093 at O’Reilly, Advance, etc
SAE 30R10 submersible, hi pressure, ethanol proof
Ordinary fuel line hose is designed to handle fuel on the inside only.
Thanks, I'll get on that. As far as I can tell, these fuel lines have the same blue markings/text and crimps that is on the external lines to the throttle bodies; looks like the factory lines?
