Im redoing some things on my 04 999S cafe racer and would like to change out the dash panel to something a little more sleek and simple but I know the stock dash, ecu, and key are all programmed to work together. So my questions are, can I just send out my ecu to get reflashed to remove the immobilizer and then use any dash I want? Can the stock ecu be reflashed? Thanks in advance.
You can flash it yourself or send it out, same result, but doing it yourself will be easier.
check out guzzidiag and tuneecu
7 long months go past and finally someone responds. i dunno. but i would keep the halo immobilizer on the ignition as it helps slow them thieves down. nice cafe bike.
