1 - 7 of 7 Posts
Hello just picked up a 999 and want to put on an open clutch cover. Do I need to install a new pressure plate to make it look sweeter? If so can a monkey like me install it myself or is it a job for my dealer? HELP, HELP
You don't need an aftermarket pressure plate, but it'll def look a little more trick if you got one with an open clutch cover.
The install is also very easy. I just posted a how-to in the tech section of this forum. It's the same procedure as with the 1098....
Vuman, I had a 999 Mono a few years ago and actually picked up the biposto rear subframe, seat, fairing etc. for around 1200 on ebay. Keep an eye out. When it came time to switch the mono for the bi it was a matter of 4 screws and a half hour later.
You can paint your original pressure plate.
1 - 7 of 7 Posts
