I had a blown headlight and the first thing I checked if it wasn't any fuse.
Turns out it was the bulb itself.
I removed all the fuses just to check them but I turned the key to the on position and when pulling one of the final fuses I guess the 3 amp one the speedometer meter began to bounce/ stutter @ around the zero.
When putting back the fuse everything works fine and the needle on power on goes all the way 13k comes back to 0 and bounces/stutters a bit ( i hear a trrrrrrt sound ) and than stops at a little over 0.
When shutting down the bike the needle moves back to exactly 0.
Everything functions fine nothing else that functions abnormally.
What could it be? And what is the solution? a TPS reset?
