Does anybody know the spec for rpm on my 05 999s? Or how to "bump" it up. It's idling at 950 rpm. And it seems that I need to rev it just a little more than I should in order to take off from a start. It doesn't stall while running in neutral or stopped in gear with clutch in but it does dip in rpm if I come to a stop suddenly and the motor rpm drops down from a higher rpm as the clutch is pulled like when you decide to stop fast instead of running the yellow and risking the red light camera
Sent from my iPad using Ducati.org Forum
