999s Restoration & Rebuild
18140 Views 97 Replies 15 Participants Last post by  edgar999s
10
Hi all, and welcome to curious visitors from Chromeheads also ;)
Thought I'd share my restoration work on the 999s. Once hailed as the 'ugly duckling', many buyers are now waking up to its timeless design. I was one of them, receiving this 2003 model with 987km in June 2020. I had little to no information to go on other than photos and the seller's word, and unfortunately the bike turned out to be a lemon, though not entirely the seller's fault - he probably just didn't know any better. I had hoped it was in good condition on the basis of the very low mileage, but that wasn't the case. Was a lot of back and forth on that sale.. Anyway, long story short, I eventually stuck with it and got a partial amount of my money back, allowing me to move forward.
Here's how she looked online -
170901
170902
170903
Day of loading up for her journey -
170904
And arrived 3 days later -
170905
Bike was known to not start. While I wasn't looking to mod or enhance it in any way, it did need a lot of my attention. Here were the early stages of me diving in, slowly opening up the can of worms. End of diagnostics concluded -
  • dead battery
  • rusted spark plugs
  • rusted vertical cylinder spark plug tunnel
  • rusted horizontal cylinder intake valve + seat
  • badly rusted fuel tank
  • ruined fuel pump
  • clogged injectors
  • worn + rusted clutch disks, basked chewed, fractured spider spring
  • evidence of crash on left side
  • spoiled oil cooler
  • degraded sound dampening material
  • leaking fork seals
  • expired stator unit
  • aged upholstery + worn rubber components
  • scratched/broken bodywork and carbon fibre components
  • bent rear brake lever bolt
  • once engine was running, coolant was found to be mixing into the oil - bad vertical head gasket
Other areas to address -
  • air filters
  • oil + coolant change
  • timing belts
  • brake + clutch bleed
  • chain + sprocket set
  • brake pads
  • tyres
  • valve adjustment
  • upgraded earth + starter wiring
  • exhaust manifold ceramic coat
170907
170908
170909
170910
Oil drain plug magnet, not too bad -
170911
1 - 20 of 98 Posts
10
State of the fuel which I drained out into a pot. I cannot express to you how much this stuff stank. My entire house reeked for about 4 days -
170912
Fuel tank interior -
170913
170914
Degraded oil cooler -
170974
Juicy spark plugs. They look amazing -
170916
Glorious fuel pump -
170917
Slowly working my way through the first phase teardown (the one needed to just get the engine running) -
170918
170919
Sad state of the sound dampening material -
170920
170921
Reactions: 1
10
Tank soaked in vinegar for 3 days. Then drained and air dried. This is the rust that came out afterwards... -
170922
Then, in with a scrubbing brush and water. Over and over until only clean water ran out -
170923
Fuel pump also vinegar soaked -
170924
Looks a lot better but the pump was still dead -
170925
Back to the fuel pump for a complete repair this time -
170926
170927
170928
DIY injector clean -
170930
170973
New plugs arrived -
170931
Reactions: 1
10
And oil + coolant change. Hoping for an engine start -
170932
Lithium attached for maximum cranking power, but dang, no luck... -
170933
At this point I came across the rusted valve. Not much I could do about it yet, it would have to be addressed during the engine teardown -
170940
170941
With a bit of further reading, I isolate and address the wiring issues -
170934
170935
And she fired up strong!! Damn what a sound. What an absolutely sensational sound. I took her for a quick lap around the neighbourhood to feel for any other issues -
170936
At this point I noticed the coolant-to-oil breach and poor clutch. Clutch inspection came out as follows -
170937
170938
170939
Reactions: 1
10
At least the first phase I was happy with. She ran. She did have some of the cutting out issues that needed to be addressed with the TPS reset, idle adjustment and TB balance in conjunction with the exhaust gases, but I'll do that after the second phase - which is the total teardown and restoration. So, diving back in -
170942
170943
Ohlins goodies off for complete overhaul -
170944
The bike came with stock and race fairings. I took the stock fairings to a vehicle centre for paint and am selling the race fairings. Scratches like this were prominent throughout -
170945
170946
Guys helping me fight the good fight. I fed them one or two parts at a time until we ran through everything -
170947
A thousand times better -
170948
They had a go at some other components as well, like the swingarm -
170949
And the carbon fibre accessories were refreshed with lacquers from a place that makes kayaks -
170950
Getting deep into it now -
170951
Reactions: 1
10
This is a familiar sight in my kitchen. Engine on the counter... -
170952
Stator definitely needs replacing -
170953
Engine cleaned, valves, pistons, gaskets etc. -
170954
170955
170956
170957
170958
One happy engine. Still needs new timing belts and valve adjustment - waiting on parts to arrive -
170959
And on to reassembly -
170960
Most definitely a two-man job. No doubt -
170961
Reactions: 1
10
Some more parts coming on - swingarm, airbox and muffler. All torqued to spec with new stainless steel bolts and copper anti-seize -
Machine Auto part Engine Technology Automotive engine part
I had a go at painting some odd parts here and there myself, like the rear wheel adjusters and sprocket carrier -
170967
Parts cleaned, restored, and waiting -
170963
170964
Wheels cleaned, new rotor bolts, bearings inspected ok. Tyres fitted and balanced - Diablo Rosso 3's, 120/70/17 front, 190/50/17 rear -
170965
Rear fitted and happy. DID 525 ZVMX with 98 links, JT Sprockets 15/38 -
170966
New pads arrived -
170968
And her very own lithium that fits -
170969
Seat back from upholstery -
170970
She's looking good! People often ask how I suspend my bikes - I hang them off my roof trusses :LOL:
170971
Reactions: 1
Ohlins goodies arrived back, so with that, I was able to sit her back down -
170972
New stator arrived and installed. Will have to see how it co-operates with the Lithium -
171072
So that's where I'm currently at. Any new work will come up in future posts. Still a bunch of stuff to address but it's coming along nicely!
All thoughts, comments and suggestions welcome :):)
Reactions: 2
Thanks mate, it's just my house hey. It's still pretty much in the exact same state - just waiting on parts at this point. Really long international shipping times!!
Reactions: 1
Great photos. And some excellent work! Wife would kill me in 2 seconds flat if she saw that in the living room.. ;-) I look forward to seeing more photos and reading of your progress.
Reactions: 1
Haha. Thank you! Assert your dominance in the house. Caveman style.
I expect parts to start arriving soon so hopefully we can get back into progress with this fine girl.
Reactions: 1
3
Hi all,
Small update here as some parts have trickled in. I got these Flennor belts which turns out have a bit of a bad reputation... Will see how they get on. These will be fitted in conjunction with the valve adjustment once I get the shim kit -
171411
Some other small items -
171412
Bike's current state. She's very patient with me...
171413
Catch up again in the next one!
POR 15 tank sealer done -
171467
That is a freaking work of art! -
171468
Exhaust manifold sent off for ceramic coat -
171487
New oil cooler arrived -
171488
Pads in, callipers cleaned and system bled -
171489
Reactions: 1
Damn that bodywork looks perfect!
That’s a rad bike!
Reactions: 1
This is going to feel like a new bike again. Congrats. I wish I had the skills to dig in like that. I admire those of you on here who can work on these bikes like this.
Reactions: 1
Thank you! Man I literally have no idea what I'm doing :LOL: This is only the second bike I've ever worked on. But I guess I do have good hands, I got that from my dad. I enjoyed taking it apart, especially the engine. It's like a feeling of exploration. Most important thing is to just read extensively and watch others do it. You gotta make the service manual your bible.
Reactions: 1
This is an insane amount of work on such a low mileage bike that looked pristine from the photos. All I have to say is congratulations on what you accomplished so far and amazing job documenting everything in this thread. This is why I have internet! Thank you Sir and keep up the good work.
Reactions: 2
10
Hi all,
Things have been ticking along and parts are rolling in slowly but surely.
A big milestone covered was the completion of the Cerakote on the exhaust. The previous tub I bought was incorrect so had to re-order. End result as follows -
171709
171710
Automotive lighting Motorcycle Automotive tire Motor vehicle Fuel tank
171712
With that, I could then finally get the new oil cooler on -
171713
Valve shim kit arrived from the States -
171714
But shortly after getting into the valve adjust, I found a fractured half-ring... :( Very strange how that happened.. When I had the engine apart in the kitchen, all half-rings were fine and intact. The engine wasn't run or anything since then and now, except the odd hand turn here and there. Oh well.. I've ordered replacements, plus a few other ancillaries.
171715
The long-awaited clutch also arrived. Installed all good. The unit is now an amalgamation of Sigma Performance and Ducabike components -
171720
171721
171722
Keep the comments and suggestions coming folks! It helps me keep going.
Reactions: 1
1 - 20 of 98 Posts
