1 - 2 of 2 Posts
hi just purchased a ducati 999s after some driving engine cut out and would not start again the engine management light is now on any ideas what could be wrong:confused:
Since everything is controlled by electronics, start with the battery. If the voltage regulator is to blame, then it won't charge the battery, won't run your fuel control system. Has the bike been sitting around? If you are lucky, it could be a loose connection at the battery. Need more specifics and history on the bike...
1 - 2 of 2 Posts
