A little over a week ago I bought a 2008 1098S in very good condition and one that has been meticulously maintained. It rode quite harsh so I attempted to adjust the suspension to accommodate my weight and there is no way I can get this to work. Most of the issues come from the rear Ohlins shock which is sprung for somebody weighing at least 250 lbs. I'm no flyweight at 195 before I put my gear on and even with the spring backed all the way off I still only get 13mm sag with the compression and rebound backed all the way out. Pushing down on the bike is like pushing down on a saw horse......it damn near refuses to move! The front isn't much better. With the spring preload backed a full 12-turns out I barely get 20 - 25mm of sag. I had heard on a couple of YouTube videos about the rear shock spring being way too stiff and I have to question why?
My recourse is to remove the rear shock and send it to Ohlins to have a lighter spring installed and have them look over the rest of the shock while it's there. Once I get that back, I'll remove the forks and send them to Ohlins to have those springs replaced, change out the weeping fork seals and also get a good looking over. What irritates me is why would Ducati install a suspension dedicated to a minority of riders based on weight? This is not going to be an inexpensive endeavor and it makes an already expensive bike into a very expensive bike for no reason. Of the 15 bikes I've owned in my life I have never encountered anything like this and that includes three other Ducatis.
I have zero intention of putting this bike on a track nor will I be storming through any twisty roads so I'm looking for a reasonably compliant suspension. What have you folks experienced and how did you handle your situation?
Thank you in advance for your replies.
rrudytoo
rrudytoo
