I know to properly adjust the idle on these things you have to hook it up to the DDS system or you have reflash the ecu etc....
Idle now is around 1200
But is there any quick fix that may not be "ideal" (I know) but would help bump up the idle a bit so my bike won't stall out right after it starts. In other words, I crack the throttle, then push the starter....bike starts and will die if I do not hold the throttle a bit open for about 10 seconds. I just want to be able to push the starter to start my bike and walk away so to speak.
Thanks guys
Thanks guys
