And if so, does anyone use the No-Mar system?
Pros?
Cons?
Others?
Thanks.
HORNETDRIVER
Pros?
Cons?
Others?
Thanks.
HORNETDRIVER
I've been using a No Mar for about 3 or 4 years. I go thru a lot of rubber and since any dealer I trust is about 2hrs away...it's been worth it. Also, I'd highly recommend the Marc Parnes balancer...great product.HORNETDRIVER said:And if so, does anyone use the No-Mar system?
Already on that one (rim scratching). I put two layers of duct tape over the rim to avoid the inevitable "clunk" that happens when pulling them off. It's worked 4.0 so far. Anyone got any good tips (besides rocking the caliper back and forth to loosen the pads) to get the calipers off? Rumor has it Ducati has a mod kit for the caliper that moves that synch line for easier removal.buckeye said:I've been using a No Mar for about 3 or 4 years. I go thru a lot of rubber and since any dealer I trust is about 2hrs away...it's been worth it. Also, I'd highly recommend the Marc Parnes balancer...great product.
The only issue with tire changing on the 1098...other than needing to be gorilla strong to remove the rear wheel nut...is getting the front calipers off without scratching your rims. The is NO margin for error so be very careful and I'd recommend taping your rim in case of an "oops"!
Doug
NVBoy,NevadaBoy said:If you find a hub adapter, could you please tell us where you got it.
I am changing my tire myself also but can't balance that rear tire because i can't find the hub adapter!
NevadaBoy
Tell Mark that Doug sent ya. I helped him with the design of the balancer for the 1098. Great guy, great product.HORNETDRIVER said:I havent heard of the Parnes balancer. I'll look into that.
Thanks for the info.
HORNETDRIVER
