1 - 17 of 17 Posts
I tend to hold on to stuff .. my $0.02
Never know when it'll come in handy -
Reactions: 219R
And haunts threads when he's been specifically asked not to. But then he was given a life ban too, and we still have to put up with his bullshit.
Back at the battery - you don't say which model you have, but this little battery isn't suitable for a Ducati twin.
At 7 amp-hours it is only for starting a small engine.
Most Ducati twins need at least 12 Ah, but prefer something greater than 16 Ah. I run an 18 Ah (Shorai) on my 1098, and a 14 Ah one on my 750 2-valve.
And yes - the LiFePO batteries can save a lot of weight, if that matters to you.
It does to me..
Discussion Starter · #9 ·
It does to me..
Thanks for the input. This is for my 1098. I am definitely going with a proper battery this time. This is the battery that was on the bike & it did give me a heck of a time to start.
It does to me..
I went with a Yuasa 12A on my 999S. Works like a charm, but I also plan to upgrade the starter cables as well,
You CAN get away with a 12 Ah for a time - many of the 1X98s came out with a 12 from standard.
While everything is good - and the heavier cables may help here - you should be OK. But on a cold morning, or after the bike has sat for a period, you won't have that margin of reserve to get you going.
Many had to upgrade the 12 Ah for something stronger, particularly on the bigger models. The 848 can manage on a 12 Ah for longer of course.
For the weight-conscious it is better to convert to a LiFePO-type battery rather than go to a smaller, lower amp-hour model. The demands on the battery for starting these, and for the fuel injection etc. at low revs, you need a fairly high-rated battery.
1 - 17 of 17 Posts
