1 - 14 of 14 Posts
Hey folks,
I just got a used Tricoloure last night. Awesome bike...really love it.
Quick question....what is the battery voltage number for most of you guys' bike?
Mine seems to be around 12.0 - 12.4. I did have to put it on the tender last night because it didn't start (previous owner rode the bike only periodically). The bike started strong this morning.
Maybe I should replace the battery?
Mike
The last two/three times I toggled through the BATT screen it was saying 14.5
BUT when I first got the bike (First 2-3 weeks) it was usually 12.5 ish.
Discussion Starter #3
Thanks. Was the 14.5 while you were riding or when the bike was off?
My bike had 1900 ish miles on it when I got it last night.
Mike
Ohh that was while it was warming up and off... right before I started her up.
Have not used a Batt Tender on it yet.
I have been toggling thru to the BATT screen the last few times before going on a ride.
I should check it later today while out riding.
Mine reads 12.4 with the engine not running and 14.5 with it running. I have also found that I have to keep it on life support as the electronics drain the batt and if I don't run it for a couple of weeks it's a tough program.
my 848 was showing 11.3 when it didn't start. it turned out that it had a bad rectifier. tech said that it's common to 1098 and probably carried over to 848.
My 848 is 14.5 when off (same battery)
No it isn't.
When not running the voltage should be somewhere near 12.5v. I would think anywhere between 12 - 12.5v is okay.
When running voltage should be somewhere near 14.5v. NOTE: if the fan kicks on the voltage drops to around 13.3v - 13.5v. It returns to 14.5 when the fan shuts off.
Personally I check that battery menu frequently. It seems that running the battery low is the worst thing that can happen. Plus I want to know if my rectifier is going bad before it causes me a real hassle.
I applaud Ducati for including a digital volt meter on the dash. I recall recently having to get out a volt meter to diagnose charging problems with an R6 while at the track. Total PITA.
Discussion Starter #11
I just checked mine again. After about 24 hours off, mine is at arounf 11.9 - 12.0. When running, it is at about 14.3 - 14.4
Mike
Folks, do not worry about these details. WHat to worry about is having a battery tender if you intend to leave your bike for any length of time in the garage - perhaps a week or more - I learnt the hard way and shelled out €99 for a new battery for my Tricolore.....
I just gotta 1198. Prev owner did not use at all. Battery did not last the trip home. Repair shop replaced the battery. On trip home it started at 12.6 When I made it home 39 mi later it read 11.3 It's on tender right now. Cant be the battery..
... it started at 12.6 When I made it home 39 mi later it read 11.3 It's on tender right now. Cant be the battery..
Right, it's not charging because of an heated-damaged in-line connector and adjacent wiring to the voltage regulator — or because of a failed regulator itself.
1 - 14 of 14 Posts
