1 - 12 of 12 Posts
Hey guys
I bled the clutch and front brake no problems recently but the rear has me a bit baffled. I've vacuum flushed the reservoir and calliper but I think the master cylinder needs bleeding too, there's no bleed nipple on it though. If I undo the nut above the banjo bolt where can I expect the fluid to leak from exactly? Will it run down the outside of the MC?
I couldn't find the info I wanted in a search. I did try :)
You have to take the caliper off and turn it upside down, the bleed it.
100% agree or you can turn your bike upside down to bleed the brake LOL
Before you flip your bike up side down, pump the brake pedal.
This can be done with a MityVac without removing the caliper.
Another trick: When you are done hang a ten pound weight from the pedal over night.
The rear brakes will be amazing after that.
Discussion Starter · #7 · (Edited)
I just rotated the calliper so bleed nipple was uppermost and held it up as high as possible, the hose routing makes that a bit limited but it seems a little better. Does it only need to be higher that the master cylinder?
I'm using a vacuum pump btw. Makes things simple for a spannering noob like me. Getting the hang of it though. Thanks for the help and advice.
Discussion Starter · #9 ·
Oh ok, sounds like I've done enough then. I'm using fluid that I've opened 4 -5 days ago, (500ml) which I kept a tight lid on and inside a ziplock bag... Indoors. Is this ok? Im assuming that whatever i flushed out of brake system will have more water in it? After this it's going in the bin.
That's how I do it. I hang it up and rotate the caliper.
I also tapping the system with a little spanner (or whats in reach ;-), starting at the pump, up the line to caliper, to help the bubbles finding their way out.
It's just a pain bleeding the rear ... imo.
1 - 12 of 12 Posts
