1 - 2 of 2 Posts
I have just installed a new Brake Master Cylinder for my bike.
The result is far better than the stock one.
This is the first time I do this Job and Luckily, everything is so far so good.
The configuration is:
1. Brembo 19 RCS Corsa Corta
2. Fren Tubo Radial Axial Adapter (You will need this thing if you don't want to change the brake line)
3. Fluid reservoir (I use the 25ml CNC racing reservoir)
4. Tygon tube.
5. Brake cleaner and a new brake fluid bottle
Video of my Configuration(My camera is out of battery and I only can not record the bleeding process) :
Land vehicle Vehicle Fuel tank Motor vehicle Automotive lighting
Bicycle Bicycles--Equipment and supplies Tire Vehicle Bicycle tire
Have a nice day!!!
1 - 2 of 2 Posts
