I'm new here. I have a 2005 749 with 8k miles. I have owned many different bikes and always wanted to build a SF.
My main question to everyone is "Has anyone successfully moved the electronics on the left of the bike to the rear or other locations.
I'm looking to move the ECU, rectifier, and power commander.
I have some room under my solo seat cowl and behind the the triple tree.
Thanks for your help.
Discussion Starter #2
Plan
Ok I think I have a plan......
Rectifier
im going to leave the rectifier, on the left side of the bike using a custom mount. I think this will fill in that dead space and more importantly it will allow good air flow around the device.
ECU
I'm going to place the ECU under the tail. I have a solo seat cowl that has room for it to mounted and not viable.
Battery
This will also go under the tail. Im going to use a compact lithium racing battery that is 1.5 x 4.25 inches.
Here is a link to the battery
https://antigravitybatteries.com/products/starter-batteries/extreme-power/sc-1/
Power Commander
I'm going to place the PC in the space between the ignition and the triple tree. There is a rather decent amount of space there.
Front Fuses
The front fuses that are in the headlight assembly will also be re located between the ignition and the triple tree.
Thoughts anyone?
Again i new to this forum, but im not new to motorcycles. I hope to find some good people to engage with. Thanks
Pics. This sounds like a cool project. Welcome to the board - it’s a little dead these days...
