Negative. The stock chain is 98 links not 108!D.I.D. ZVMX is a good one or the RK GXW line is also good. I believe the 848 uses 108 links. It's what is suggested. Some of the guys, myself included, added a link to get the wheel base a little longer.
Right you are. Knew there was an 8 in there somewhere.Negative. The stock chain is 98 links not 108!
525 Chain Kit - SUPERLITE Steel Sprocket Set with Your Choice of X'ring Chain - DUCATI 848 SBK '08-13 - Complete Chain & Sprocket Kits - 848 SBK 2008-2013 - Ducati - STREET ProductsWhat is a good source to get a kit with stock gearing?
