You've been given a few solutions to your problem and all will work. Most axel sliders allow the use of spool stands or use something that will slide through your axel and allow a spool stand to lift the rear tire I've used a piece of rebar before. Depending on your rear sets you can also use jack stands underneath the pegs the hold the rear tire in the air.I have the chain cleaner and brush. I need a way of getting the rear up so I can spend the chain
Wow none of u clean the chain on your 999
