OK. I've had what I describe as a SQUEAL in my clutch when I pull a hole shot or put a high rev start into it. The squeal causes the clutch to slip and not respond as it should when you most need ot to.
I've posted this problem and a few other guys have said they had the same problem and after many trips to the dealer it was fixed by simply cleaning the clutch. I have a manual and have worked on WET clutches many times. I will do this myself but I have a querstion. If the clutch is to remain dry, what do you clean it with? Brake cleaner? Do the rings go back in 100% dry? No lube at all and no residue from cleaners??
Help me out here.
Help me out here.
