Most SS springs also increase clutch resistance (require more effort to compress). As a direct result, the effort it takes to pull in your clutch increases. For track use, this may be looked at as a plus, but for everyday street, it'll only add to the already strenuous Ducati clutch.
Last but not least, the rust issue... As long as you don't hose your bike or let it sit in the rain for days on end (without use), you really shouldn't have a rust issue with OEM hardware. It's all about common sense. If the clutch pack gets wet, after you're done washing it down, start the bike up and let it idle for just a few minutes. You can also gently cycle her through a few small revs to speed the process up. Between the heat and the spinning action of the clutch itself, all the water (the little amount that's trapped in there) will ultimately disappear.
That's what I have been doing to all my Duc's since 1999 and I have never had any rust issues...
