I'm sure this has been asked before but I'm in a bit of a hurry, so I don't feel like searching now....how do I take the clutch hub off?? I took the hub nut off, bushing, washer, all the plates, and nothing. Can't pull the damn thing off. Is there something else holding it that I'm missing, or is there a trick to get it off?
The other question is what's the minimum thickness of the OEM plates (both steel and friction) supposed to be before you need to change them? I'm changing to a slipper clutch, and was planning on using the stock plates, but now that I took them off I just want to make sure that they're still within spec.
