,,I did,but on my return home it had leaked out.I went ahead and removed the slave and out of the pee hole came fluid and while pulling the lever you can see and hear it escaping,fawk.Looking part # 195.4.003.1A ,may as well replace it.Didn't you just swap the push rod o rings and seals? Can't remember if that was you or someone else on the ST3 section.
,,Serious ? is it part #195.4.003.1A ,,:ahhh: you got my attention sir..LMKI have a stocker off my 1098 I'll send you for cheap.
...The transplant part from the 1098 was a success,it live's....:drummer:,,thanks vfr-Hombre..I have a stocker off my 1098 I'll send you for cheap.
Not really a fair comment.Saying the oem is garbage? TYe says so it must be true..
I wonder how in the world I have over 30k miles out of mine..
