D) you are shortening the service life of your tranny
Either use the clutch or get a quick shifter w/auto blooper if you're too lazy.
Yes you can change gears without using the clutch. Doesn't necessarily mean the tranny is on its way out. BUT IT WILL BE. Your first Duc is a 1098? So I'm guessing it's used. How many miles? Was it dealer serviced its whole life? The answers will help you figure how close you are to needing to replace the engagement dogs, shift forks, etc.
