I have a beautiful crafted set of CNC handlebar switches. Left and right side. Plug and play into your factory harness. Install in 10mins! Be done with the crappy plastic units. FITMENT FOR ALL VARIATIONS OF 848/1098/1198/SBK/SF/DESMOSIDICI.
Retain all factory functions/modes/menus.
LEFT SWITCH
The switch body is machined from full 7075 aluminium (Ergal) bars and has then undergone a hard black anodizing process that enhances processing with CNC machinery. All the buttons compliant with the IP67 military standard that certifies the switch itself is water resistant. The operation of all buttons is guaranteed by over 700,000 cycles.
Assembly is very easy and plug&play: just dismantle the original switch with the tools recommended by the Manufacturer and the master cylinder clamp; then fit the CNC Racing switch connecting the plug to the bike original cable. Nothing else is required and you can always go back to the original configuration without any modification.
Front buttons
Blue - Beam
Yellow - Turn indicator right
Black - Mode
Green - Turn indicator left
Grey - Horn
Rear Buttons
Red - UP
Green - Down
RIGHT SWITCH
Right handlebar switch for OEM and RCS Brembo brake master cylinder.
Red button - ignition circuit activator / breaker
Black button - engine starter activation
Grey button - activator / breaker option button multiple uses,can be customised by Customer
Would prefer to sell as a set. These retail for over $600EURO from CNC racing directly .
I'm looking for $500USD for the pair + shipping
I accept Paypal as "friends and family " or add fees
