If you do your own work and have a CO tester, eliminate them. But if you do eliminate them, make sure the bike is more on the rich side, which means you'll need to use something like GuzziDiag (if it works with your ECU) or have a map that is slightly on the rich side.
If you ever plan on an open air box you'll want a richer map anyway.
