1 - 3 of 3 Posts
I had a problem with my 2007 1098s starting and it turned out to be the starter.
Well I took it all apart and was able to replace the starter with a new one.
I went to put the left case/stator cover back on and started tightening the bolts and bigger than shit I cracked it! :mad:
I had a bit of trouble getting the outer cover to meet up with the inside but as far as I know there was nothing in the way and the bolts all seemed to line up.
Maybe I should have tapped around the edges with a rubber mallet.
I've ordered another cover but I'd really appreciate some tips to prevent me from busting another cover.
You probably didn't have it centered on the crankshaft. You've gotta tap it on with a rubber mallet so it's all the way on before tightening it. I actually keep the puller tool in place when re-assembling and use that as a tapping place. It works really well.
FYI, there is a bearing in the cover that your new one may not come with. Just double check that before re-installing and if suspect, replace it. That bearing is a critical part and it can contaminate the lubrication system if it's damaged.
I'm betting the water pump drive was not engaged in the timing shaft slot. A VERY easy detail to miss! It will hold the case just a few mm off the surface even after the crank bearing is well located........... Where did it crack?
1 - 3 of 3 Posts
