I'm planning to replace the crank position sensor on my 2008 1098 with original CPS. I'm having an issue with the rear cylinder not firing. I have spark, fuel, & compression. I am now thinking CPS is firing the coil at the wrong time.
I was wondering if the 848/1198 CPS is compatible with the 1098. There are two different part numbers and as far as I can tell, the only difference is the wire exits the side of the 848/1198 sensor instead of the top like the 1098 sensor.
848/1098R/1198: 55241321A
1098: 55240201A
1098: 55240201A
